hydrogen - Printable Version +- Carolina Broncos (https://cb4x4.com) +-- Forum: Web Site (https://cb4x4.com/forum-4.html) +--- Forum: Cut Loose (https://cb4x4.com/forum-18.html) +--- Thread: hydrogen (/thread-837.html) |
hydrogen - trkbilder - 07-10-2008 bucketobolts Wrote:So can someone post up some actual numbers?OK guys, you've gone and done it!!! You've got Aaron thinking, this is what I've been talking about, get the brightest minds on the problem and we will move ahead!!! The problem will be beaten because some one asked WHY DOES IT DO THAT!!!!:xyxthumbs: hydrogen - redsblue73 - 07-10-2008 [SIZE="3"]"Save the Bronco"....."Ride a Cowboy!!![/SIZE]:rebel:....:chili: hydrogen - bucketobolts - 07-10-2008 I still don't think that you can produce enough hydrogen with 12V and a few ounces of water to make much of a difference. Then how are you going to meter this gas to the engine? Just dump it in to the intake? hydrogen - redsblue73 - 07-10-2008 I hate to jump in but i have seen this work also.....but the guy had to install a potentiometer to the map sensor so it wouldn't read too lean. The thing is you had two settings...highway and in town....and you had to switch back and forth. this would ensure proper fuel mixture for the type of driving your doing.:drinkbud::xyxthumbs::hysterical: ![]() |
